주요 콘텐츠로 건너뛰기
HP Envy 23-d060qd TouchSmart Speaker Replacement
필요한 것
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: 4 단계, 이미지 1개 중 1개
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: 5 단계, 이미지 2개 중 1개 HP Envy 23-d060qd TouchSmart Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: 6 단계, 이미지 2개 중 1개 HP Envy 23-d060qd TouchSmart Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: 7 단계, 이미지 2개 중 1개 HP Envy 23-d060qd TouchSmart Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
결론
작성자
6다른 기여자 명과 함께
Zachary Dicks
회원 가입일: 10/01/15
1,135 평판
안내서 7개를 작성함
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 회원
CPSU-MANESS-F15S5G10
4 회원들
안내서 14개를 작성함
댓글 한 개
where to get the replacement speaker???????
Clovis Young - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 13
지난 30일: 36
전체 시간: 1,566
