주요 콘텐츠로 건너뛰기
HP Envy 4520 AC Adapter Replacement
필요한 것
  1. HP Envy 4520 AC Adapter Replacement, AC Adapter: 1 단계, 이미지 1/1
    • Ensure that the printer is turned off.
    • Locate and remove the black power cord from the back of the printer.
  2. HP Envy 4520 AC Adapter Replacement: 2 단계, 이미지 1/2 HP Envy 4520 AC Adapter Replacement: 2 단계, 이미지 2/2
    • Lift the top of the printer.
    • Using the plastic opening tool, remove the clip holding the scanner bed up by prying the clip away from the the side of the scanner bed.
  3. HP Envy 4520 AC Adapter Replacement: 3 단계, 이미지 1/3 HP Envy 4520 AC Adapter Replacement: 3 단계, 이미지 2/3 HP Envy 4520 AC Adapter Replacement: 3 단계, 이미지 3/3
    • Remove the six 14 mm T10 Hex screws.
    • Pry the plastic cover off using the blue opening tool.
  4. HP Envy 4520 AC Adapter Replacement: 4 단계, 이미지 1/2 HP Envy 4520 AC Adapter Replacement: 4 단계, 이미지 2/2
    • Locate the the AC adapter at the top left corner of the device which is connected by intertwined red and blue wires.
  5. HP Envy 4520 AC Adapter Replacement: 5 단계, 이미지 1/3 HP Envy 4520 AC Adapter Replacement: 5 단계, 이미지 2/3 HP Envy 4520 AC Adapter Replacement: 5 단계, 이미지 3/3
    • Remove the adapter by pinching the plastic head of the wire connector and pulling it out of the port.
결론
다른 3명이 해당 안내서를 완성하였습니다.
katie hartwig
회원 가입일: 09/26/18
133 평판
안내서 1개 작성함
댓글 2개
Forgot a step at the beginning. Have to remove the inside clip connected to the lid. If you only remove the outside clip in step 2 and not the inside clip, it will snap. This clip triggers the cartridges to slide to the left when the lid is open for replacement.
harmspjf harmspjf - 답글
Where is this "Inside Clip" located, and how do you do you remove it?
azbobcat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 1,426
