주요 콘텐츠로 건너뛰기
HP Envy 5660 LCD Replacement
필요한 것
  1. HP Envy 5660 LCD Replacement, LCD: 1 단계, 이미지 1/1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: 2 단계, 이미지 1/2 HP Envy 5660 LCD Replacement: 2 단계, 이미지 2/2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: 3 단계, 이미지 1/3 HP Envy 5660 LCD Replacement: 3 단계, 이미지 2/3 HP Envy 5660 LCD Replacement: 3 단계, 이미지 3/3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: 4 단계, 이미지 1/2 HP Envy 5660 LCD Replacement: 4 단계, 이미지 2/2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: 5 단계, 이미지 1/2 HP Envy 5660 LCD Replacement: 5 단계, 이미지 2/2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: 6 단계, 이미지 1/1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Steakley
회원 가입일: 01/23/18
781 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - 답글
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 1,103
