소개
The scanner glass for the HP Envy 5660 may receive cracks over time. This guide will help the user replace the scanner glass.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
