주요 콘텐츠로 건너뛰기
HP Envy 700-030qe CD Drive Replacement
필요한 것
  1. HP Envy 700-030qe CD Drive Replacement, CD Drive: 1 단계, 이미지 1/2 HP Envy 700-030qe CD Drive Replacement, CD Drive: 1 단계, 이미지 2/2
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CD Drive Replacement: 2 단계, 이미지 1/2 HP Envy 700-030qe CD Drive Replacement: 2 단계, 이미지 2/2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe CD Drive Replacement: 3 단계, 이미지 1/1
    • For the next step, remove the CD drive power cable.
  4. HP Envy 700-030qe CD Drive Replacement: 4 단계, 이미지 1/1
    • Reorient the device with the front pointing away from you.
    • Next, remove the SATA interface cable. It is directly next to the power cable on the CD drive.
  5. HP Envy 700-030qe CD Drive Replacement: 5 단계, 이미지 1/1
    • Now pull up and swing the mounting lever in. The lever closest to the front mounts the top drive slot, and the lever farther away mounts the bottom one.
  6. HP Envy 700-030qe CD Drive Replacement: 6 단계, 이미지 1/2 HP Envy 700-030qe CD Drive Replacement: 6 단계, 이미지 2/2
    • Now stand your desktop up and remove the 3 clips on the right side of the front panel.
    • Then pull the front panel off, pulling from the side that the clips are on.
  7. HP Envy 700-030qe CD Drive Replacement: 7 단계, 이미지 1/1
    • Now you can pull the CD drive straight out of the casing!
결론
Yoav Rosenberg
회원 가입일: 10/01/15
321 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 회원
CPSU-MANESS-F15S5G9
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,099
