주요 콘텐츠로 건너뛰기
HP Envy 700-030qe Power Supply Replacement
필요한 것
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: 1 단계, 이미지 1/3 HP Envy 700-030qe Power Supply Replacement, Power Supply: 1 단계, 이미지 2/3 HP Envy 700-030qe Power Supply Replacement, Power Supply: 1 단계, 이미지 3/3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: 2 단계, 이미지 1/2 HP Envy 700-030qe Power Supply Replacement: 2 단계, 이미지 2/2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: 3 단계, 이미지 1/1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: 4 단계, 이미지 1/2 HP Envy 700-030qe Power Supply Replacement: 4 단계, 이미지 2/2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: 5 단계, 이미지 1/1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: 6 단계, 이미지 1/1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: 7 단계, 이미지 1/1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: 8 단계, 이미지 1/1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: 9 단계, 이미지 1/1
    • Unplug the power cable going to the fan by pulling straight up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Yoav Rosenberg
회원 가입일: 10/01/15
321 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 회원
CPSU-MANESS-F15S5G9
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 32
전체 시간: 4,320
