소개
If your are having problems turning on the computer your power supply might be at fault. If you need to replace it you will need to remove the side panel, disconnect and dismount the power supply.
필요한 것
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
다른 2명이 해당 안내서를 완성하였습니다.
