주요 콘텐츠로 건너뛰기
HP Envy 700-030qe Solid State Drive Replacement
필요한 것
  1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: 1 단계, 이미지 1/1
    • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
    • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
  2. HP Envy 700-030qe Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
    • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
  3. HP Envy 700-030qe Solid State Drive Replacement: 3 단계, 이미지 1/1
    • Turn the computer onto its side to continue removing the case cover.
    • Slide the cover off by sliding it to the right.
  4. HP Envy 700-030qe Solid State Drive Replacement: 4 단계, 이미지 1/2 HP Envy 700-030qe Solid State Drive Replacement: 4 단계, 이미지 2/2
    • Locate the SSD inside the open case.
    • Unplug the SATA power cable from the hard drive by pulling straight up.
  5. HP Envy 700-030qe Solid State Drive Replacement: 5 단계, 이미지 1/1
    • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
  6. HP Envy 700-030qe Solid State Drive Replacement: 6 단계, 이미지 1/1
    • To remove the SSD and its casing, pull out on the side silver tab.
    • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
  7. HP Envy 700-030qe Solid State Drive Replacement: 7 단계, 이미지 1/1
    • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
    • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
  8. HP Envy 700-030qe Solid State Drive Replacement: 8 단계, 이미지 1/1
    • Finally, slide the SSD out of the casing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Chandler Warne
회원 가입일: 10/01/15
273 평판
안내서 1개 작성함
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 회원
CPSU-MANESS-F15S5G9
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 33
전체 시간: 2,560
