주요 콘텐츠로 건너뛰기
HP Envy M6-1205DX Fan Replacement
필요한 것
  1. HP Envy M6-1205DX Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Fan Replacement: 2 단계, 이미지 1/1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Fan Replacement: 3 단계, 이미지 1/2 HP Envy M6-1205DX Fan Replacement: 3 단계, 이미지 2/2
    • Remove the battery.
  4. HP Envy M6-1205DX Fan Replacement, Touchpad: 4 단계, 이미지 1/1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Fan Replacement: 5 단계, 이미지 1/1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Fan Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Fan Replacement: 7 단계, 이미지 1/1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Fan Replacement: 8 단계, 이미지 1/2 HP Envy M6-1205DX Fan Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Fan Replacement: 9 단계, 이미지 1/2 HP Envy M6-1205DX Fan Replacement: 9 단계, 이미지 2/2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Fan Replacement: 10 단계, 이미지 1/2 HP Envy M6-1205DX Fan Replacement: 10 단계, 이미지 2/2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Fan Replacement: 11 단계, 이미지 1/3 HP Envy M6-1205DX Fan Replacement: 11 단계, 이미지 2/3 HP Envy M6-1205DX Fan Replacement: 11 단계, 이미지 3/3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Fan Replacement: 12 단계, 이미지 1/3 HP Envy M6-1205DX Fan Replacement: 12 단계, 이미지 2/3 HP Envy M6-1205DX Fan Replacement: 12 단계, 이미지 3/3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Fan Replacement: 13 단계, 이미지 1/1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Fan Replacement: 14 단계, 이미지 1/2 HP Envy M6-1205DX Fan Replacement: 14 단계, 이미지 2/2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Fan Replacement, Fan: 15 단계, 이미지 1/1
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Fan Replacement: 16 단계, 이미지 1/1
    • Pull the fan out to remove it.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alex Wasilewski
회원 가입일: 09/28/16
596 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 5,691
