소개
In this guide, you will learn how to safely replace the motherboard on the HP Envy m6-1205dx. Some reasons to do this may be, to fix damaged components, improve performance, stability, reliability, and make future upgrades easier. A few problems can be solved with a replacement motherboard such as hardware incompatibility, motherboard failure, and outdated technology. Before attempting to replace the motherboard be sure to have fully powered off the computer and disconnected the computer from any external power source. This is not a simple task as you will need to disassemble a lot of the laptop.
필요한 것
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
Using a Philips #1, remove the five 5.0 mm screws.
Gently pull the mini power connectors to remove them.
Gently pull the two ribbon cables to remove them.
Pull the black tab to remove the LCD screen connector.
다른 3명이 해당 안내서를 완성하였습니다.
