주요 콘텐츠로 건너뛰기
HP Envy M6-1205DX RAM Replacement
필요한 것
  1. HP Envy M6-1205DX RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX RAM Replacement: 2 단계, 이미지 1/1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX RAM Replacement: 3 단계, 이미지 1/2 HP Envy M6-1205DX RAM Replacement: 3 단계, 이미지 2/2
    • Remove the battery.
  4. HP Envy M6-1205DX RAM Replacement, Back Panel: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX RAM Replacement: 5 단계, 이미지 1/1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX RAM Replacement, RAM: 6 단계, 이미지 1/1
    • To release the RAM push out on the two release mechanisms holding it down.
  7. HP Envy M6-1205DX RAM Replacement: 7 단계, 이미지 1/1
    • Lift gently up on the RAM to position it for removal.
  8. HP Envy M6-1205DX RAM Replacement: 8 단계, 이미지 1/1
    • Gently pull the RAM out of its slot.
  9. HP Envy M6-1205DX RAM Replacement: 9 단계, 이미지 1/1
    • Upon removing the first stick of RAM you will find a second RAM stick located beneath it.
    • Release the second RAM stick by pushing the two release mechanisms outward.
    • Pull the RAM stick out.
결론
Ryan Hatton
회원 가입일: 11/16/19
634 평판
안내서 5개 작성하였습니다
IUPUI, Team S2-G2, Wilson Fall 2019 IUPUI, Team S2-G2, Wilson Fall 2019 회원
IUPUI-WILSON-F19S2G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 256
