주요 콘텐츠로 건너뛰기
HP Envy M6-1205DX Screen Replacement
필요한 것
  1. HP Envy M6-1205DX Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Screen Replacement: 2 단계, 이미지 1/1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Screen Replacement: 3 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 3 단계, 이미지 2/2
    • Remove the battery.
  4. HP Envy M6-1205DX Screen Replacement, Touchpad: 4 단계, 이미지 1/1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Screen Replacement: 5 단계, 이미지 1/1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Screen Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Screen Replacement: 7 단계, 이미지 1/1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Screen Replacement: 8 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Screen Replacement: 9 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 9 단계, 이미지 2/2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Screen Replacement: 10 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 10 단계, 이미지 2/2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Screen Replacement: 11 단계, 이미지 1/3 HP Envy M6-1205DX Screen Replacement: 11 단계, 이미지 2/3 HP Envy M6-1205DX Screen Replacement: 11 단계, 이미지 3/3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Screen Replacement: 12 단계, 이미지 1/3 HP Envy M6-1205DX Screen Replacement: 12 단계, 이미지 2/3 HP Envy M6-1205DX Screen Replacement: 12 단계, 이미지 3/3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Screen Replacement: 13 단계, 이미지 1/1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Screen Replacement: 14 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 14 단계, 이미지 2/2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Screen Replacement, Hinges: 15 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement, Hinges: 15 단계, 이미지 2/2
    • Pull up on the black tab to unplug the cable that goes into the screen
    • The cable will be stuck onto the motherboard and will need to be pulled off. The adhesive is very weak and the cable will stick back down when you are finished.
  16. HP Envy M6-1205DX Screen Replacement: 16 단계, 이미지 1/1
    • Using a Phillps #1, remove the two 5.6mm silver screws from the base of the first hinge.
  17. HP Envy M6-1205DX Screen Replacement: 17 단계, 이미지 1/1
    • Also using a Phillips #1, remove the two 5.6mm silver screws from the base of the second hinge.
  18. HP Envy M6-1205DX Screen Replacement: 18 단계, 이미지 1/1
    • Using a plastic opening tool, carefully start prying the frame of the screen up
  19. HP Envy M6-1205DX Screen Replacement: 19 단계, 이미지 1/1
    • When prying the screen frame off be careful around the top edge as your webcam will be there. It is a safe idea to move it out of the way like am I doing now.
  20. HP Envy M6-1205DX Screen Replacement: 20 단계, 이미지 1/1
    • Remove the three 1.9mm silver screws from the base of the screen frame using the Phillips 00 screwdriver.
    • If you are doing this guide as a prerequisite to replace the screen, stop here and skip ahead to step 23
  21. HP Envy M6-1205DX Screen Replacement: 21 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 21 단계, 이미지 2/2
    • Carefully pry the edge of the frame up to expose the other half of the first hinge.
    • Using a Phillips #1, remove the three 2.8mm silver screws.
    • Pull the hinge out.
  22. HP Envy M6-1205DX Screen Replacement: 22 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement: 22 단계, 이미지 2/2
    • Care full pry up the other corner of the frame
  23. HP Envy M6-1205DX Screen Replacement, Screen: 23 단계, 이미지 1/2 HP Envy M6-1205DX Screen Replacement, Screen: 23 단계, 이미지 2/2
    • Using a Phillips #00, remove the four 2.3 mm black screws.
    • Lift the screen and frame out of the computer body.
  24. HP Envy M6-1205DX Screen Replacement: 24 단계, 이미지 1/1
    • Flip the screen over
    • There is a black cable that is connected to the screen through the frame.
    • Pull pack the tape that holds the cable in
    • Pull the cable out to remove it.
  25. HP Envy M6-1205DX Screen Replacement: 25 단계, 이미지 1/1
    • Pull the black tape that is attached to the frame off of the screen
결론
다른 5명이 해당 안내서를 완성하였습니다.
Alex Wasilewski
회원 가입일: 09/28/16
596 평판
안내서 5개 작성하였습니다
댓글 한 개
Pueden decirme qué modelos de pantalla son compatibles con la Envy m6 1205dx? necesito cambiar el mio y veo varios para Envy m6 diferentes
jt6288 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 2,199
