주요 콘텐츠로 건너뛰기
HP Envy Sleekbook m6-k010dx Battery Replacement
필요한 것
  1. HP Envy Sleekbook m6-k010dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Battery Replacement: 2 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Battery Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Battery Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Battery Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Battery Replacement: 5 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Battery Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ana Novo
회원 가입일: 02/14/18
410 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 회원
USFT-NANCE-S18S1G4
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
I am going to give this a try.. I took it to Best Buy Geek Squad, they had it for over 3 weeks and said they couldn’t find the part cause my laptop is to old. This wasn’t the only issue. The touchpad wasn’t working and I troubleshooted the problem and I fixed it myself.
I will add another comment once i replace the battery
momw4boys - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 42
전체 시간: 9,029
