주요 콘텐츠로 건너뛰기
HP Envy Sleekbook m6-k010dx Fan Replacement
필요한 것
  1. HP Envy Sleekbook m6-k010dx Fan  Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Fan  Replacement: 2 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Fan  Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Fan  Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Fan  Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Fan  Replacement: 5 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Fan  Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx Fan  Replacement, Fan: 6 단계, 이미지 1/1
    • Remove two 3mm Phillips #00 screws from the fan.
  7. HP Envy Sleekbook m6-k010dx Fan  Replacement: 7 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Fan  Replacement: 7 단계, 이미지 2/2
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  8. HP Envy Sleekbook m6-k010dx Fan  Replacement: 8 단계, 이미지 1/1
    • Lift the fan upwards to remove it from the computer.
결론
Ana Novo
회원 가입일: 02/14/18
410 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 회원
USFT-NANCE-S18S1G4
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 609
