주요 콘텐츠로 건너뛰기
HP Envy Sleekbook m6-k010dx Keyboard Replacement
필요한 것
  1. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 2 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 5 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Fan: 6 단계, 이미지 1/1
    • Remove two 3mm Phillips #00 screws from the fan.
  7. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 7 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  8. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 8 단계, 이미지 1/1
    • Lift the fan upwards to remove it from the computer.
  9. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Keyboard: 9 단계, 이미지 1/1
    • Flip up the black tab on the ZIF connector and pull the blue and white flex cable connecting the touchpad to the motherboard.
  10. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 10 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 10 단계, 이미지 2/2
    • Remove three 3mm Phillips #00 screws from the SD card board.
    • Remove the SD card board.
  11. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 11 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 11 단계, 이미지 2/2
    • In order to remove the RAM, pull each silver clip (one at a time) away from the RAM.
    • The RAM chip should pop up. Gently remove the RAM from the motherboard.
  12. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 12 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 12 단계, 이미지 2/2
    • Remove four 3mm Phillips #00 screws from the heatsink.
    • Lift the heat sink out from the device and set it aside.
  13. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 13 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 13 단계, 이미지 2/2
    • Remove the black and white antenna wires from the Wi-Fi card.
  14. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 14 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 14 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 14 단계, 이미지 3/3
    • Remove the two 3mm Phillips #00 screws that secure the speaker to the device.
    • Remove the four 4mm Phillips #00 screws from the bracket.
    • Locate the speaker cable connecting the speaker to the audio board. Gently tug on this cable to dislodge. Set the speaker aside.
  15. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 15 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 15 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 15 단계, 이미지 3/3
    • Remove the two 3mm Phillips #00 screws that secure the RJ-45 module.
    • Lift the white tab on the ZIF connector and pull the ribbon cable out.
  16. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 16 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 16 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 16 단계, 이미지 3/3
    • Remove the 3mm Phillips #00 screw connecting the chip to the housing.
    • Lift up silver bracket.
    • Lift up the white flap on the ZIF connector and remove the purple ribbon cable.
  17. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 17 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 17 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 17 단계, 이미지 3/3
    • Remove the cover for the RM-45 port.
    • Gently lift and remove the chip from its housing.
  18. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 18 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 18 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 18 단계, 이미지 3/3
    • Remove the 4mm Phillips #00 screws.
    • Remove the silver 3mm Phillips 3 mm screw.
    • Lift all three black flaps in the ZIF connectors and remove the attached ribbon cables.
  19. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 19 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 19 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 19 단계, 이미지 3/3
    • Use your hand and gently remove the connector to the back up battery for the motherboard.
    • Remove the four 4mm Phillips #00 screws from the motherboard.
    • Lift the board at an angle and pull outwards to dislodge it from the device.
  20. HP Envy Sleekbook m6-k010dx Keyboard Replacement: 20 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: 20 단계, 이미지 2/2
    • Remove the thirteen silver 3mm Phillips #00 screws that secure the keyboard to the frame.
    • Lift up the keyboard from the bracket and pull outwards to remove the keyboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
codi whittaker
회원 가입일: 02/14/18
508 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 회원
USFT-NANCE-S18S1G4
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,860
