주요 콘텐츠로 건너뛰기
HP Envy Sleekbook m6-k010dx LCD Replacement
필요한 것
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: 2 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx LCD Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: 5 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx LCD Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: 6 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: 6 단계, 이미지 2/2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: 7 단계, 이미지 1/1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: 8 단계, 이미지 1/3 HP Envy Sleekbook m6-k010dx LCD Replacement: 8 단계, 이미지 2/3 HP Envy Sleekbook m6-k010dx LCD Replacement: 8 단계, 이미지 3/3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: 9 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx LCD Replacement: 9 단계, 이미지 2/2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: 10 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx LCD Replacement: 10 단계, 이미지 2/2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: 11 단계, 이미지 1/1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
codi whittaker
회원 가입일: 02/14/18
508 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 회원
USFT-NANCE-S18S1G4
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 931
