주요 콘텐츠로 건너뛰기
HP Envy Sleekbook m6-k010dx TouchPad Replacement
필요한 것
  1. HP Envy Sleekbook m6-k010dx TouchPad Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 2 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 5 단계, 이미지 1/2 HP Envy Sleekbook m6-k010dx TouchPad Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx TouchPad Replacement, TouchPad: 6 단계, 이미지 1/1
    • Lift the white tab on the ZIF connector to unlock the ribbon cable.
    • Pull the ribbon cable out of the ZIF connector.
  7. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 7 단계, 이미지 1/1
    • Remove the seven 3mm Phillips #00 screws from the trackpad.
  8. HP Envy Sleekbook m6-k010dx TouchPad Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool to lift the touchpad up and pull out to remove.
결론
codi whittaker
회원 가입일: 02/14/18
508 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 회원
USFT-NANCE-S18S1G4
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 35
전체 시간: 661
