주요 콘텐츠로 건너뛰기
HP Envy TouchSmart 15 Digitizer Replacement
필요한 것
  1. HP Envy TouchSmart 15 Digitizer Replacement, Touch Screen/Digitizer: 1 단계, 이미지 1/1
    • Lay the laptop down with the bottom facing up.
  2. HP Envy TouchSmart 15 Digitizer Replacement: 2 단계, 이미지 1/1
    • Slide the switch to release the battery and remove it.
  3. HP Envy TouchSmart 15 Digitizer Replacement: 3 단계, 이미지 1/2 HP Envy TouchSmart 15 Digitizer Replacement: 3 단계, 이미지 2/2
    • Remove the screw from the access panel. Gently lift and remove the panel.
  4. HP Envy TouchSmart 15 Digitizer Replacement: 4 단계, 이미지 1/3 HP Envy TouchSmart 15 Digitizer Replacement: 4 단계, 이미지 2/3 HP Envy TouchSmart 15 Digitizer Replacement: 4 단계, 이미지 3/3
    • Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
  5. HP Envy TouchSmart 15 Digitizer Replacement: 5 단계, 이미지 1/3 HP Envy TouchSmart 15 Digitizer Replacement: 5 단계, 이미지 2/3 HP Envy TouchSmart 15 Digitizer Replacement: 5 단계, 이미지 3/3
    • Remove the screws to loosen the bottom casing.
    • Remove the two feet to reveal the screws underneath.
  6. HP Envy TouchSmart 15 Digitizer Replacement: 6 단계, 이미지 1/1
    • Gently pry the edges to loosen the case.
    • Once loose, lift and remove the plastic casing to reveal the motherboard.
  7. HP Envy TouchSmart 15 Digitizer Replacement: 7 단계, 이미지 1/2 HP Envy TouchSmart 15 Digitizer Replacement: 7 단계, 이미지 2/2
    • Lift and detach the wireless antenna cables.
    • Lift and de-route the wires from their tracks until you reach the display hinges.
  8. HP Envy TouchSmart 15 Digitizer Replacement: 8 단계, 이미지 1/1
    • Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
  9. HP Envy TouchSmart 15 Digitizer Replacement: 9 단계, 이미지 1/2 HP Envy TouchSmart 15 Digitizer Replacement: 9 단계, 이미지 2/2
    • Remove the screws from each hinge.
    • Lift the hinges with pliers until they are perpendicular to the case.
    • Lift and remove the bottom of the laptop from the screen.
  10. HP Envy TouchSmart 15 Digitizer Replacement: 10 단계, 이미지 1/1
    • Lift the tabs in both the bottom corners and remove the screws beneath.
  11. HP Envy TouchSmart 15 Digitizer Replacement: 11 단계, 이미지 1/2 HP Envy TouchSmart 15 Digitizer Replacement: 11 단계, 이미지 2/2
    • Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
  12. HP Envy TouchSmart 15 Digitizer Replacement: 12 단계, 이미지 1/3 HP Envy TouchSmart 15 Digitizer Replacement: 12 단계, 이미지 2/3 HP Envy TouchSmart 15 Digitizer Replacement: 12 단계, 이미지 3/3
    • Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
    • Gently peel the digitizer away from the plastic border.
    • When installing the new one digitizer, press firmly around the edges.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Micah Kempf
회원 가입일: 03/30/16
260 평판
안내서 1개 작성함
Michigan Tech, Team 1-12, Lauer Spring 2016 Michigan Tech, Team 1-12, Lauer Spring 2016 회원
MTU-LAUER-S16S1G12
1 회원
안내서 1개 작성하였습니다
댓글 4개
These directions are perfect. I was able to successfully change my digitizer in under an hour
Joe Russo - 답글
where do you get the digitizer?
Jacob - 답글
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson Odimgbe - 답글
Nevelson, I have updated this page to included a link to the part on amazon.
Micah Kempf - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 21
전체 시간: 14,134
