주요 콘텐츠로 건너뛰기
HP Envy TouchSmart 15 Hard Drive Replacement
필요한 것
  1. HP Envy TouchSmart 15 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: 3 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: 3 단계, 이미지 2개 중 2개
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Envy TouchSmart 15 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Envy TouchSmart 15 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  6. HP Envy TouchSmart 15 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ramon Villadonga
회원 가입일: 09/04/15
1,035 평판
안내서 5개를 작성함
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G6
4 회원들
안내서 10개를 작성함
댓글 6개
Thanks man! Worked great.
Charles Uibel - 답글
Thank you! I was worried about the step to remove the accessory plate, but seeing this tutorial helped reassure me that I wasn't going to break it. Very interesting design choice by HP...
Rob Kachmar - 답글
What’s the hard disk size in case I want to buy a replacement? In terms of inches. I see online that most of the laptop hard disks are quoted as 2.5 or 3 inch
Bwana Lawi - 답글
2.5 inches. I fitted the Samsung 850 EVO, fits perfectly.
cbrowne91 - 답글
Thanks found the guide helpful. However I caused myself a problem by breaking the black hdd retaining clip on the motherboard. It was so fragile that I’m sure this has happened to others???? Any repair ideas anyone? As you imagine I’d be grateful of a resolution.
Arthur David Mc Kee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 29
전체 시간: 12,863
