주요 콘텐츠로 건너뛰기
HP Envy TouchSmart 15 Solid State Drive Replacement
필요한 것
  1. HP Envy TouchSmart 15 Solid State Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Solid State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: 3 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: 3 단계, 이미지 2개 중 2개
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Solid State Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Envy TouchSmart 15 Solid State Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Envy TouchSmart 15 Solid State Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 2개 중 2개
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. HP Envy TouchSmart 15 Solid State Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Envy TouchSmart 15 Solid State Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ramon Villadonga
회원 가입일: 09/04/15
1,035 평판
안내서 5개를 작성함
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G6
4 회원들
안내서 10개를 작성함
댓글 2개
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
temidayoabayomizannu - 답글
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 20
전체 시간: 3,011
