주요 콘텐츠로 건너뛰기
HP Envy Touchsmart m6-k125dx Hard Drive Replacement
필요한 것
  1. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/2 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: 2 단계, 이미지 1/1
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Using the JIS screwdriver along with the J000 head, unscrew the four Phillips PM2.5x5.5 screws, and place them aside.
  4. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: 4 단계, 이미지 1/1
    • Carefully detach the Hard Drive Adapter, and remove the Hard Drive from the laptop.
    • Make sure not to pull from the cord; pull from the head of the adapter.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Conner Anderson
회원 가입일: 09/25/17
213 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 1,138
