소개
This repair requires a size 0 Phillips head screwdriver and a plastic opening tool. If you think that you are having an issue with your battery, but are not sure, follow this guide to access the battery for troubleshooting purposes. In addition, if you have determined that there is a problem with the battery and you have obtained a replacement, you can use this guide to replace the battery as well.
Removing the battery may be a necessary prerequisite for performing replacement of a different part of the device as well. In this case, this guide can also be useful for learning how to perform this first step.
필요한 것
Make sure that the device is turned off and that all external devices are removed.
