Use this guide to replace the broken display on your HP Envy Ultrabook 4-1015dx.
Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
Make sure not to lose these internal screws; they will later be used to reattach the battery.
The hard disk drive is under a metallic looking case in the bottom-right corner of the device.
Using a size 0 Phillips head screwdriver, remove the four 3 mm size 0 screws attaching the hard drive casing to the device.
Using the plastic opening tool, pry out the small chip next to the touch pad that is attached via ribbon cable to the motherboard. Make sure to pry from the side that only has one small black bump, rather than the side that has two.
The chip should be located underneath the ribbon cables, which is reflected in the first image.
Using a size 0 Phillips head screwdriver, remove the two metallic 3 mm Phillips head screws.
Once the screws are removed, the LAN adapter should pop up. Pull out the LAN adapter from its socket.
Remove clasp beneath the headphone port.
Using a size 0 Phillips head screwdriver, remove the 3 mm size 0 Phillips head screw that attaches the clasp to the device.
Then, take off the clasp.
Remove the fan.
Use a size 0 Phillips head screwdriver to remove the 3 mm size 0 screw attaching the fan to the device.
Pull the fan out of the slot and, using the plastic opening tool, unplug the connector cable from the socket.
Remove the subwoofer.
Using plastic opening tool, remove the red and black subwoofer cable.
Use a size 0 Phillips head screwdriver to remove the two 3 mm size 0 screws attaching the subwoofer to the device.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
