주요 콘텐츠로 건너뛰기
HP Envy Ultrabook 4-1043cl Cooling Fan Replacement
필요한 것
  1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 2 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 4 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 5 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 2/2
    • Remove one 4.2mm screw at the bottom right corner by using the Phillips #00 screwdriver.
  7. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 7 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: 7 단계, 이미지 2/2
    • Disconnect the fan from the motherboard and remove it from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shen Zhao
회원 가입일: 10/01/19
376 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 222
