주요 콘텐츠로 건너뛰기
HP Envy Ultrabook 4-1043cl Hard Drive Replacement
필요한 것
  1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 2 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 4 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 5 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: 6 단계, 이미지 3/3
    • The hard drive is in the bottom right corner of the device which is packed by a silver metal shell.
    • Use a Phillips #00 screwdriver to remove the four 4.0 mm screws securing the hard drive to the top cover.
  7. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 7 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 7 단계, 이미지 2/2
  8. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 8 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: 8 단계, 이미지 2/2
    • Pull the hard disk drive out of the connector socket and remove it from the device.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Shen Zhao
회원 가입일: 10/01/19
376 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 565
