주요 콘텐츠로 건너뛰기
HP Envy Ultrabook 4-1043cl RAM Replacement
필요한 것
  1. HP Envy Ultrabook 4-1043cl RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl RAM Replacement: 2 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl RAM Replacement: 2 단계, 이미지 2/2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl RAM Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl RAM Replacement: 4 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl RAM Replacement: 4 단계, 이미지 2/2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl RAM Replacement: 5 단계, 이미지 1/2 HP Envy Ultrabook 4-1043cl RAM Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: 6 단계, 이미지 1/3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: 6 단계, 이미지 2/3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: 6 단계, 이미지 3/3
    • The RAM lies in the middle-right side of the device.
    • Use your fingers and push the two clips outwards to release the RAM stick.
  7. HP Envy Ultrabook 4-1043cl RAM Replacement: 7 단계, 이미지 1/1
    • Remove the RAM from the device.
  8. HP Envy Ultrabook 4-1043cl RAM Replacement: 8 단계, 이미지 1/3 HP Envy Ultrabook 4-1043cl RAM Replacement: 8 단계, 이미지 2/3 HP Envy Ultrabook 4-1043cl RAM Replacement: 8 단계, 이미지 3/3
    • Repeat the previous two steps to remove any other RAM sticks.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 291
