주요 콘텐츠로 건너뛰기
HP Envy X2-15-C001Dx Speakers Replacement
필요한 것
  1. HP Envy X2-15-C001Dx Speakers Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Speakers Replacement: 2 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 2 단계, 이미지 2/2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Speakers Replacement: 3 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 3 단계, 이미지 2/2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Speakers Replacement: 4 단계, 이미지 1/1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Speakers Replacement: 5 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 5 단계, 이미지 2/2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Speakers Replacement: 6 단계, 이미지 1/1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Speakers Replacement: 7 단계, 이미지 1/1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Speakers Replacement: 8 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 8 단계, 이미지 2/2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Speakers Replacement: 9 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 9 단계, 이미지 2/2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Speakers Replacement: 10 단계, 이미지 1/2 HP Envy X2-15-C001Dx Speakers Replacement: 10 단계, 이미지 2/2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Speakers Replacement, Speakers: 11 단계, 이미지 1/1
    • Flip up the black retaining flap securing the speaker's ribbon cable.
    • Slide the ribbon cable out of the connector.
  12. HP Envy X2-15-C001Dx Speakers Replacement: 12 단계, 이미지 1/1
    • Disconnect the black speaker wire from the motherboard.
  13. HP Envy X2-15-C001Dx Speakers Replacement: 13 단계, 이미지 1/1
    • Lift the left speaker up and away from the laptop.
  14. HP Envy X2-15-C001Dx Speakers Replacement: 14 단계, 이미지 1/1
    • Unplug the black right speaker wire from its connection on the motherboard.
    • Lift the right speaker out of the laptop to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dylan Hathaway
회원 가입일: 10/25/21
686 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 122
