주요 콘텐츠로 건너뛰기
HP Envy dv7t-7200 Battery Replacement
  1. HP Envy dv7t-7200 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Battery Replacement: 2 단계, 이미지 1/3 HP Envy dv7t-7200 Battery Replacement: 2 단계, 이미지 2/3 HP Envy dv7t-7200 Battery Replacement: 2 단계, 이미지 3/3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Battery Replacement: 3 단계, 이미지 1/1
    • Tilt the battery away from you and lift out.
결론
Krystal
회원 가입일: 10/16/17
882 평판
안내서 8개 작성하였습니다
UW Tacoma, Team S3-G3, Liner Fall 2017 UW Tacoma, Team S3-G3, Liner Fall 2017 회원
UWT-LINER-F17S3G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 226
