주요 콘텐츠로 건너뛰기
HP Envy dv7t-7200 Keyboard Assembly Replacement
필요한 것
  1. HP Envy dv7t-7200 Keyboard Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Keyboard Assembly Replacement: 2 단계, 이미지 1/3 HP Envy dv7t-7200 Keyboard Assembly Replacement: 2 단계, 이미지 2/3 HP Envy dv7t-7200 Keyboard Assembly Replacement: 2 단계, 이미지 3/3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Keyboard Assembly Replacement: 3 단계, 이미지 1/1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Keyboard Assembly Replacement, Service Cover: 4 단계, 이미지 1/1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Keyboard Assembly Replacement: 5 단계, 이미지 1/2 HP Envy dv7t-7200 Keyboard Assembly Replacement: 5 단계, 이미지 2/2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Keyboard Assembly Replacement, Optical Disc Drive: 6 단계, 이미지 1/1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Keyboard Assembly Replacement: 7 단계, 이미지 1/2 HP Envy dv7t-7200 Keyboard Assembly Replacement: 7 단계, 이미지 2/2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Keyboard Assembly Replacement: 8 단계, 이미지 1/2 HP Envy dv7t-7200 Keyboard Assembly Replacement: 8 단계, 이미지 2/2
    • Slide the disk drive out of the laptop.
  9. HP Envy dv7t-7200 Keyboard Assembly Replacement, Keyboard Assembly: 9 단계, 이미지 1/1
    • Place the laptop on it’s top
    • Remove the two screws that secure the keyboard to the laptop.
  10. HP Envy dv7t-7200 Keyboard Assembly Replacement: 10 단계, 이미지 1/1
    • Stand the laptop on it’s left side with it’s top open.
    • Locate the circular opening in the optical drive slot.
    • Using a plastic opener, press on the keyboard through this opening until it lifts the keyboard away.
  11. HP Envy dv7t-7200 Keyboard Assembly Replacement: 11 단계, 이미지 1/1
    • Place the laptop on it’s back with the front facing you.
    • Using a plastic opener, lift the back of the keyboard towards you releasing it from the lip that holds it.
    • You will hear slight popping noises as the keyboard separates.
  12. HP Envy dv7t-7200 Keyboard Assembly Replacement: 12 단계, 이미지 1/1
    • The keyboard is still attached by two ribbon cables. Lift the keyboard slowly during this step.
    • Lift keyboard up and place upside down on laptop.
  13. HP Envy dv7t-7200 Keyboard Assembly Replacement: 13 단계, 이미지 1/1
    • Release the connectors that attach the keyboard to the laptop.
  14. HP Envy dv7t-7200 Keyboard Assembly Replacement: 14 단계, 이미지 1/1
    • Remove the keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Krystal
회원 가입일: 10/16/17
882 평판
안내서 8개 작성하였습니다
UW Tacoma, Team S3-G3, Liner Fall 2017 UW Tacoma, Team S3-G3, Liner Fall 2017 회원
UWT-LINER-F17S3G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 363
