소개
Use this guide to replace a faulty motherboard on your HP Envy dv7t-7200 if you want an updated processor or if your motherboard shorted out.
필요한 것
Place the computer on its top on a flat surface with the hinges facing away from you.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
Place the laptop on it’s top
Remove the two screws that secure the keyboard to the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
