주요 콘텐츠로 건너뛰기
HP Envy dv7t-7200 Optical Disc Drive Replacement
필요한 것
  1. HP Envy dv7t-7200 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Optical Disc Drive Replacement: 2 단계, 이미지 1/3 HP Envy dv7t-7200 Optical Disc Drive Replacement: 2 단계, 이미지 2/3 HP Envy dv7t-7200 Optical Disc Drive Replacement: 2 단계, 이미지 3/3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Optical Disc Drive Replacement: 3 단계, 이미지 1/1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Optical Disc Drive Replacement, Service Cover: 4 단계, 이미지 1/1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Optical Disc Drive Replacement: 5 단계, 이미지 1/2 HP Envy dv7t-7200 Optical Disc Drive Replacement: 5 단계, 이미지 2/2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Optical Disc Drive Replacement, Optical Disc Drive: 6 단계, 이미지 1/1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Optical Disc Drive Replacement: 7 단계, 이미지 1/2 HP Envy dv7t-7200 Optical Disc Drive Replacement: 7 단계, 이미지 2/2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Optical Disc Drive Replacement: 8 단계, 이미지 1/2 HP Envy dv7t-7200 Optical Disc Drive Replacement: 8 단계, 이미지 2/2
    • Slide the disk drive out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Krystal
회원 가입일: 10/16/17
882 평판
안내서 8개 작성하였습니다
UW Tacoma, Team S3-G3, Liner Fall 2017 UW Tacoma, Team S3-G3, Liner Fall 2017 회원
UWT-LINER-F17S3G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 129
