주요 콘텐츠로 건너뛰기
HP Envy m6-1105dx Keyboard Replacement
필요한 것
  1. HP Envy m6-1105dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx Keyboard Replacement: 2 단계, 이미지 1/1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx Keyboard Replacement: 4 단계, 이미지 1/3 HP Envy m6-1105dx Keyboard Replacement: 4 단계, 이미지 2/3 HP Envy m6-1105dx Keyboard Replacement: 4 단계, 이미지 3/3
    • Remove the two JIS #0 screws that secure the keyboard to the computer.
    • Partially open the computer and rest it on its side.
    • Insert a plastic opening tool into the keyboard release holes on the inside of the battery area.
    • Press on the back of the keyboard until the keyboard disengages from the computer.
  5. HP Envy m6-1105dx Keyboard Replacement: 5 단계, 이미지 1/2 HP Envy m6-1105dx Keyboard Replacement: 5 단계, 이미지 2/2
    • Return the computer to its normal position, facing you and open.
    • Lift the rear edge of the keyboard.
    • Lift the keyboard towards the front of the computer, keeping it on an angle.
    • Lift the side of the keyboard until you can access the keyboard cable and the keyboard backlight cable.
  6. HP Envy m6-1105dx Keyboard Replacement: 6 단계, 이미지 1/2 HP Envy m6-1105dx Keyboard Replacement: 6 단계, 이미지 2/2
    • Release the keyboard connector cable (the wider of the two cables) by lifting the thin edge resting on top of the cable.
    • Disconnect the cable from the system board.
    • Disconnect the thinner backlight cable from the system board by pulling gently on the tab.
  7. HP Envy m6-1105dx Keyboard Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard.
결론
Melody Veldorale
회원 가입일: 10/19/18
305 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 UMass Dartmouth, Team S1-G5, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G5
5 회원들
안내서 4개 작성하였습니다
댓글 한 개
Unfortunately the instructions for the keyboard release inside the battery area don't really tell you which direction you should turn it. I'm afraid I'll break the plastic.
RabblerouserGT - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 1,173
