주요 콘텐츠로 건너뛰기
HP Envy m6-1105dx RAM Replacement
  1. HP Envy m6-1105dx RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx RAM Replacement: 2 단계, 이미지 1/1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx RAM Replacement: 4 단계, 이미지 1/2 HP Envy m6-1105dx RAM Replacement: 4 단계, 이미지 2/2
    • Push the silver levers on either side of the memory module away from the module.
    • Remove the memory module by gently pulling it on an angle away from the slot.
결론
Melody Veldorale
회원 가입일: 10/19/18
305 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 UMass Dartmouth, Team S1-G5, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G5
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 396
