주요 콘텐츠로 건너뛰기
HP Envy m6-1105dx WLAN Card Replacement
필요한 것
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: 2 단계, 이미지 1/1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: 3 단계, 이미지 1/1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: 4 단계, 이미지 1/2 HP Envy m6-1105dx WLAN Card Replacement: 4 단계, 이미지 2/2
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: 5 단계, 이미지 1/3 HP Envy m6-1105dx WLAN Card Replacement: 5 단계, 이미지 2/3 HP Envy m6-1105dx WLAN Card Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: 6 단계, 이미지 1/2 HP Envy m6-1105dx WLAN Card Replacement: 6 단계, 이미지 2/2
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
결론
Ian Mwalago
회원 가입일: 10/14/18
303 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 UMass Dartmouth, Team S1-G5, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G5
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 607
