주요 콘텐츠로 건너뛰기
HP Envy m6-1225dx Optical Drive Replacement
필요한 것
  1. HP Envy m6-1225dx Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Optical Drive Replacement: 2 단계, 이미지 1/3 HP Envy m6-1225dx Optical Drive Replacement: 2 단계, 이미지 2/3 HP Envy m6-1225dx Optical Drive Replacement: 2 단계, 이미지 3/3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Optical Drive Replacement: 3 단계, 이미지 1/1
    • Remove the battery
  4. HP Envy m6-1225dx Optical Drive Replacement: 4 단계, 이미지 1/2 HP Envy m6-1225dx Optical Drive Replacement: 4 단계, 이미지 2/2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Optical Drive Replacement: 5 단계, 이미지 1/2 HP Envy m6-1225dx Optical Drive Replacement: 5 단계, 이미지 2/2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Optical Drive Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Optical Drive Replacement: 7 단계, 이미지 1/2 HP Envy m6-1225dx Optical Drive Replacement: 7 단계, 이미지 2/2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Optical Drive Replacement: 8 단계, 이미지 1/1
    • Pull the optical drive out of the base of the laptop.
결론
Lucas Nelson
회원 가입일: 01/30/20
581 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 167
