주요 콘텐츠로 건너뛰기
HP Envy m6-1225dx TouchPad Buttons Replacement
필요한 것
  1. HP Envy m6-1225dx TouchPad Buttons Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx TouchPad Buttons Replacement: 2 단계, 이미지 1/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 2 단계, 이미지 2/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 2 단계, 이미지 3/3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx TouchPad Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the battery
  4. HP Envy m6-1225dx TouchPad Buttons Replacement: 4 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx TouchPad Buttons Replacement: 5 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement: 5 단계, 이미지 2/2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx TouchPad Buttons Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx TouchPad Buttons Replacement: 7 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement: 7 단계, 이미지 2/2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx TouchPad Buttons Replacement: 8 단계, 이미지 1/1
    • Pull the optical drive out of the base of the laptop.
  9. HP Envy m6-1225dx TouchPad Buttons Replacement, TouchPad Buttons: 9 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement, TouchPad Buttons: 9 단계, 이미지 2/2
    • Remove the 4 screws from the hard drive bracket with a Phillips #1 screwdriver.
  10. HP Envy m6-1225dx TouchPad Buttons Replacement: 10 단계, 이미지 1/1
    • Disconnect the cable from the side of the hard drive and move it to the side
    • Remove the hard drive from the laptop.
    • Our laptop did not have a hard drive when we disassembled it.
  11. HP Envy m6-1225dx TouchPad Buttons Replacement: 11 단계, 이미지 1/1
    • Remove the two screws that secure the keyboard to the laptop using a Phillips #1 screwdriver.
  12. HP Envy m6-1225dx TouchPad Buttons Replacement: 12 단계, 이미지 1/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 12 단계, 이미지 2/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 12 단계, 이미지 3/3
    • Move the laptop onto its left side with it open.
    • Turn the laptop and look into the empty battery slot for two release holes.
    • Insert a metal spudger into the release holes and apply pressure to the back of the keyboard till it comes loose of the laptop.
  13. HP Envy m6-1225dx TouchPad Buttons Replacement: 13 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement: 13 단계, 이미지 2/2
    • Gently lift the keyboard away from the laptop.
    • Remove the cable connection from the base of the laptop.
    • Remove the keyboard backlight cable.
    • The keyboard backlight cable is only present on select models.
  14. HP Envy m6-1225dx TouchPad Buttons Replacement: 14 단계, 이미지 1/2 HP Envy m6-1225dx TouchPad Buttons Replacement: 14 단계, 이미지 2/2
    • Remove the 13 screws on the bottom of the laptop using a Phillips #1 screwdriver.
  15. HP Envy m6-1225dx TouchPad Buttons Replacement: 15 단계, 이미지 1/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 15 단계, 이미지 2/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 15 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the power button board cable using a pair of tweezers.
    • Disconnect the touchpad button board cable using tweezers.
    • Disconnect the fingerprint reader board cable using tweezers.
    • Disconnect the right speaker cable using tweezers.
    • Remove the 4 screws using a Phillips #1 screwdriver.
    • Apply force to the base of the cover to pop if off from the laptop base.
    • Be sure the cable for the right speaker doesn't get caught on the cover as it is removed or the speaker could be damaged.
  16. HP Envy m6-1225dx TouchPad Buttons Replacement: 16 단계, 이미지 1/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 16 단계, 이미지 2/3 HP Envy m6-1225dx TouchPad Buttons Replacement: 16 단계, 이미지 3/3
    • Turn the top cover with the touchpad area facing you.
    • Remove the one screw holding the touchpad buttons down with a Phillips #1 screwdriver.
    • Disconnect the cable holding the touchpad buttons to the top cover
결론
Lucas Nelson
회원 가입일: 01/30/20
581 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 366
