소개
This guide demonstrates how to properly remove the CPU of a HP Envy m6-n010dx.
필요한 것
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the 6 highlighted 1.5 mm screws using a #00 philips head screwdriver.
Pry off the lower two grip pads highlighted in orange.
Remove the two additional 1.5mm screws underneath the lower grip pads using a #00 philips head screwdriver.
Remove the large back panel to reveal the inner workings.
The CPU can be found underneath the heatsink, highlighted in yellow.
To reassemble your device, follow these instructions in reverse order. Be sure to apply new thermal paste if you are using a new CPU.
다른 3명이 해당 안내서를 완성하였습니다.
