주요 콘텐츠로 건너뛰기
HP Envy m6-n010dx Fan Replacement
필요한 것
  1. HP Envy m6-n010dx Fan Replacement, Battery: 1 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement, Battery: 1 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Fan Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Fan Replacement: 3 단계, 이미지 1/2 HP Envy m6-n010dx Fan Replacement: 3 단계, 이미지 2/2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Fan Replacement: 4 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement: 4 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement: 4 단계, 이미지 3/3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Fan Replacement, Fan: 5 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement, Fan: 5 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement, Fan: 5 단계, 이미지 3/3
    • Remove the screws highlighted in red
    • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Fan Replacement: 6 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement: 6 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement: 6 단계, 이미지 3/3
    • Locate fan
    • Gently remove tape that hold the heatsink and fan together
    • When reassembling , make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Fan Replacement: 7 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement: 7 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement: 7 단계, 이미지 3/3
    • Loosen the four screws on the heat sink indicated in picture
    • Remove the heatsink
  8. HP Envy m6-n010dx Fan Replacement: 8 단계, 이미지 1/2 HP Envy m6-n010dx Fan Replacement: 8 단계, 이미지 2/2
    • Gently disconnect the wire connecting the fan to the motherboard
  9. HP Envy m6-n010dx Fan Replacement: 9 단계, 이미지 1/3 HP Envy m6-n010dx Fan Replacement: 9 단계, 이미지 2/3 HP Envy m6-n010dx Fan Replacement: 9 단계, 이미지 3/3
    • Remove screws indicated in photo.
    • Remove fan
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sandra Ramirez
회원 가입일: 02/08/18
247 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 1,058
