주요 콘텐츠로 건너뛰기
HP Envy m6-n010dx Hard Drive Replacement
필요한 것
  1. HP Envy m6-n010dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Envy m6-n010dx Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Envy m6-n010dx Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Hard Drive Replacement: 3 단계, 이미지 1/2 HP Envy m6-n010dx Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Hard Drive Replacement: 4 단계, 이미지 1/3 HP Envy m6-n010dx Hard Drive Replacement: 4 단계, 이미지 2/3 HP Envy m6-n010dx Hard Drive Replacement: 4 단계, 이미지 3/3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Morales
회원 가입일: 02/08/18
393 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 1,276
