주요 콘텐츠로 건너뛰기
HP Envy m6-n010dx Speaker Replacement
필요한 것
  1. HP Envy m6-n010dx Speaker Replacement, Battery: 1 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement, Battery: 1 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Speaker Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Speaker Replacement: 3 단계, 이미지 1/2 HP Envy m6-n010dx Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Speaker Replacement: 4 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement: 4 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement: 4 단계, 이미지 3/3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Speaker Replacement, Speaker: 5 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement, Speaker: 5 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement, Speaker: 5 단계, 이미지 3/3
    • Remove the marked screws.
    • Pry off the lower two grip pads.
    • You may need to use more force than feels necessary.
    • Remove the two additional screws underneath the lower grip pads.
    • Remove the large back panel to reveal the inner workings.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Speaker Replacement: 6 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement: 6 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement: 6 단계, 이미지 3/3
    • Locate the speaker.
    • Locate the tape on the speaker.
    • Peel back the tape, disconnecting it from the speaker.
    • When reassembling the speaker, make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Speaker Replacement: 7 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement: 7 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement: 7 단계, 이미지 3/3
    • Locate the connecting wire attached to the speaker.
    • Disconnect the wire.
  8. HP Envy m6-n010dx Speaker Replacement: 8 단계, 이미지 1/2 HP Envy m6-n010dx Speaker Replacement: 8 단계, 이미지 2/2
    • Use a screwdriver to unscrew the three screws on the speaker.
  9. HP Envy m6-n010dx Speaker Replacement: 9 단계, 이미지 1/3 HP Envy m6-n010dx Speaker Replacement: 9 단계, 이미지 2/3 HP Envy m6-n010dx Speaker Replacement: 9 단계, 이미지 3/3
    • Remove the speaker.
결론
Justin Lee
회원 가입일: 02/08/18
144 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 268
