주요 콘텐츠로 건너뛰기
HP Envy m6-p114dx Battery Replacement
필요한 것
  1. HP Envy m6-p114dx Battery Replacement, Back Panel: 1 단계, 이미지 1/3 HP Envy m6-p114dx Battery Replacement, Back Panel: 1 단계, 이미지 2/3 HP Envy m6-p114dx Battery Replacement, Back Panel: 1 단계, 이미지 3/3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Battery Replacement: 2 단계, 이미지 1/1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Battery Replacement: 3 단계, 이미지 1/1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Battery Replacement, Battery: 4 단계, 이미지 1/2 HP Envy m6-p114dx Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
  5. HP Envy m6-p114dx Battery Replacement: 5 단계, 이미지 1/2 HP Envy m6-p114dx Battery Replacement: 5 단계, 이미지 2/2
    • Remove the cable connecting the battery to the motherboard by gripping the fabric and pulling downward.
    • The cable is connected next to the RAM cards.
  6. HP Envy m6-p114dx Battery Replacement: 6 단계, 이미지 1/2 HP Envy m6-p114dx Battery Replacement: 6 단계, 이미지 2/2
    • Remove the six screws that hold the battery down with a Phillips #0 screwdriver.
    • Once the screws are removed you should be able to easily lift up on the battery to remove it. (You may need to detach the ribbon cable glued to the battery )
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Cheney
회원 가입일: 08/26/19
527 평판
안내서 4개 작성하였습니다
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 1,007
