소개
In this guide, you will learn how to remove the hard drive in order to either replace, upgrade, or manage the hard drive.
필요한 것
Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
Lift directly up to remove the main speaker.
Gently pull the wire out of the plastic track that it's set in.
There are wires over some of the screws, use a thin implement to get the wires out of their track.
Unplug the SATA cable from the motherboard (covered in the teardown for the battery).
Remove the 4 screws
Remove the Hard drive from the unit
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks for this guide. It really helped out and drastically sped up the whole process.
I needed to install a 2.5" SSD and new RAM to my girlfriend's machine and have never opened up a HP laptop.
Appreciate all the effort that went in to this!
