주요 콘텐츠로 건너뛰기
HP Envy m6-p114dx Speaker Replacement
필요한 것
  1. HP Envy m6-p114dx Speaker Replacement, Back Panel: 1 단계, 이미지 1/3 HP Envy m6-p114dx Speaker Replacement, Back Panel: 1 단계, 이미지 2/3 HP Envy m6-p114dx Speaker Replacement, Back Panel: 1 단계, 이미지 3/3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Speaker Replacement: 3 단계, 이미지 1/1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Speaker Replacement, Speaker: 4 단계, 이미지 1/3 HP Envy m6-p114dx Speaker Replacement, Speaker: 4 단계, 이미지 2/3 HP Envy m6-p114dx Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
    • Lift directly up to remove the main speaker.
    • Gently pull the wire out of the plastic track that it's set in.
  5. HP Envy m6-p114dx Speaker Replacement: 5 단계, 이미지 1/1
    • Follow the cable around the inside of the case and remove the cable to the main board
    • Once this is removed you can fully remove the speaker!
결론
Shad Padilla
회원 가입일: 08/26/19
112 평판
안내서 1개 작성함
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 182
