주요 콘텐츠로 건너뛰기
HP Envy x2 13-j002dx Battery Replacement
필요한 것
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: 3 단계, 이미지 1/1
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: 4 단계, 이미지 1/2 HP Envy x2 13-j002dx Battery Replacement: 4 단계, 이미지 2/2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: 5 단계, 이미지 1/1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: 6 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: 7 단계, 이미지 1/2 HP Envy x2 13-j002dx Battery Replacement: 7 단계, 이미지 2/2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: 8 단계, 이미지 1/1
    • Carefully lift up and remove the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aaron Page
회원 가입일: 01/17/19
418 평판
안내서 1개 작성함
댓글 한 개
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 20
전체 시간: 1,901
