소개
These instructions will guide you through the process to remove and replace the motherboard on the HP Envy x2 13-j002dx (Model #J9M64UA). In step 1 of this guide, you will remove the tablet’s outer shell to access the motherboard. The rest of guide shows you how to remove and replace the motherboard.
필요한 것
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
다른 한 분이 해당 안내서를 완성하였습니다.
