주요 콘텐츠로 건너뛰기
HP Envy x2 13-j002dx Screen Replacement
필요한 것
  1. HP Envy x2 13-j002dx Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Screen Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Screen Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Screen Replacement: 4 단계, 이미지 1/2 HP Envy x2 13-j002dx Screen Replacement: 4 단계, 이미지 2/2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Screen Replacement: 5 단계, 이미지 1/1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Screen Replacement: 6 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Screen Replacement: 7 단계, 이미지 1/2 HP Envy x2 13-j002dx Screen Replacement: 7 단계, 이미지 2/2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Screen Replacement: 8 단계, 이미지 1/1
    • Carefully lift up and remove the battery.
  9. HP Envy x2 13-j002dx Screen Replacement, Motherboard: 9 단계, 이미지 1/1
    • Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
  10. HP Envy x2 13-j002dx Screen Replacement: 10 단계, 이미지 1/2 HP Envy x2 13-j002dx Screen Replacement: 10 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
  11. HP Envy x2 13-j002dx Screen Replacement: 11 단계, 이미지 1/2 HP Envy x2 13-j002dx Screen Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
  12. HP Envy x2 13-j002dx Screen Replacement: 12 단계, 이미지 1/2 HP Envy x2 13-j002dx Screen Replacement: 12 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
    • Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
  13. HP Envy x2 13-j002dx Screen Replacement: 13 단계, 이미지 1/1
    • Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
  14. HP Envy x2 13-j002dx Screen Replacement, Screen: 14 단계, 이미지 1/1
    • Once the battery and motherboard are removed, the screen unit should offer little resistance. Remove the screen from the base.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Colton Moon
회원 가입일: 11/04/19
241 평판
안내서 2개 작성하였습니다
Idaho State University, Team S1-G3, Watkins Fall 2019 Idaho State University, Team S1-G3, Watkins Fall 2019 회원
ISU-WATKINS-F19S1G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 712
