소개
If you are having trouble with the battery life of your device or if your device will not turn on, it may be time for a replacement battery. This guide will provide step-by-step instructions for how to remove the battery on an HP Envy x360 13-y013cl laptop. Be aware of any swelling in the battery as there may be an increased risk of combustion. Before starting the guide, ensure to power off the device, drain the battery to 0 percent, and disconnect the power source.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
