주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Hard Drive Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Hard Drive Replacement: 5 단계, 이미지 1/2 HP Envy x360 15-bp143cl Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift the black tab securing the hard drive connecting cable to the laptop to remove the cable.
  6. HP Envy x360 15-bp143cl Hard Drive Replacement: 6 단계, 이미지 1/1
    • Lift the hard drive from its slot.
    • If the hard drive is attached using adhesive, use an opening tool to pry it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Berkins
회원 가입일: 10/10/19
574 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 회원
CPSU-REGAN-F19S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 1,117
