주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Motherboard Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Motherboard Replacement: 5 단계, 이미지 1/2 HP Envy x360 15-bp143cl Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Peel off the tape securing the heatsink.
  8. HP Envy x360 15-bp143cl Motherboard Replacement: 8 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
    • Detach the fan cable from the mother board.
  9. HP Envy x360 15-bp143cl Motherboard Replacement: 9 단계, 이미지 1/1
    • Lift the fan up and off the motherboard.
  10. HP Envy x360 15-bp143cl Motherboard Replacement: 10 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
    • Pull the four cables directly out of their ports.
    • Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
  11. HP Envy x360 15-bp143cl Motherboard Replacement: 11 단계, 이미지 1/1
    • Gently lift the motherboard up and out of the chassis.
결론
Thomas Schemm
회원 가입일: 02/11/22
304 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 29
전체 시간: 768
