주요 콘텐츠로 건너뛰기
소개
The touch screen can be damage or wear out over time. This guide will show how to replace the touch screen of your device.
  1. Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws. Remove the two 3mm screws using the J00 Phillips screwdriver.
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. Remove the four 3mm screws using the Phillips #00 screwdriver.
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen. There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
결론
Maximillian McDonald
회원 가입일: 2018년 01월 13일
607 평판
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 49
지난 30일: 422
전체 시간: 2,743
